Re: megane 2 con doble din
hola , mira el modelo es Modelo : AS-7208 googlealo te paso una web que lo vende no se donde jaja Navegador específico Renault Megane powerplanet as 7208 a buen precio - Powerplanetonline no se si abara entrado a argentina
RENAULT MEGANE navigation dvd player system.
1) Car DVD SYSTEM FOR RENAULT MEGANE With Multifunctional Steering Wheel Controller
2) 7" 16:9 TFT Digital LCD Monitor,Pixel:800*480
4) Touch Screen with Graphic OSD display.
5) Auto Dimmer(Standard/bright/soft/customer video mode)
6) Play DVD/ DivX./MP4/VCD/CD/MP3
7) With USB/SD&MMC slot. Double SD, One SD: Player MP3/WMA/AVI/MPEG/JPEG ; One SD,One GPS map
8) Super Sensitive TV Receiver.
9) Super Sensitive FM/AM/ RDS Radio.
10) Built-in 4X50W Amplifier.
11) Super Bass output 5.1 Mode
12) Intelligent Clock Display.
13) 1 AV Output(3 Zone) 1 AV Input.
14) Steering Wheel Control.
15) Built-in Bluetooth
16) Car Camera in.
17) Ready for Navigation Input interface.(Main Unit Can Control).
18) Electronic Anti-Shock Protection
19) Support i-Pod control
19) Built-in GPS system
Dimension: 200mm(up width) * 195mm (below width)* 125mm(height)Product characteristic: 1. According to the original car design, without crack installation, don¡¯t cut line and only need to insert the socket into the original plug when you install.
2. Can listen to the Radio , DVD , TV , USB and SD file when operate the GPS.
3. 3 Zone function, watching DVD in the front and watching TV from the back Monitor at the same time.
General Section:
1) Power Supply: DC12V(10.8V-16V)
2) Current Consumption: Less Than 10A
3) Operational Temperature Range: -20C to +85C Audio Section:
1) Rated Output: 4ch X 23W (1KHz, 1%, 4 ohm)
2) Maximum Power Output: 4chX50W
3) Rated Speaker Impedance: 4 ohm
4) Pre-AMP Output Voltage: 2Vrms
5) Pre-AMP Output Impedance: <220ohm
6) AV Input/Output Section
7) Video: 1 Vp-p(75 ohm)
8) Audio: 500mVrmsMonitor Section:
1) Picture Size: 7 inche wide144(w)X80(H)mm
2) Display System: TFT LCD panel
3) Number of pixels: 336.960 pixels(1200HX234VXRGB)
4) Video System: PAL / NTSC
5) Beightness: 400cd/m2FM Stereo Radio Section:
Frequency Range:
1) U.S.Standard: 87.9-107.9MHz
2) Outside U.S.: 87.5-108.0MHz
3) Usable Sensitivity: 5dBuV(S/N=30dB)
4) S/N ratio: >60dBTV Tuner Section:
1) Colour System: NTSC, PAL-B/G, PAL-I, PAL-D/K,PAL-M,PAL-N
2) Channel Selection System:PLL Frequency Synthesizer System
3) Usable Sensitivity: 41dBuVGPS section:
1) Power specification:DC-12V
2) Working current:<300MA
3) Standby state current:0MA
4) Working temperature:-20C to +70C
5) Operation system:Windows CE 4.2
6) CPU:Intel PXA255 Processor,Max.main frequency 400MHZ.
7) SDRAM/FLASH:1GB/64 MB
8) GPS receive speed: 8 channel ,Orientation time of cold boot is 92S,Orientation time of warm boot is 37S,Orientation time of hot boot is 19S
9) Orientation presicion:<15m
10) Refurbish frequency:1HZ
11) GPS antenna frequency:1575.52MHZ
12) Length of antenna:5M
13) Voice indication:Intellectualized voice indication function
14) Display output:CVBS+S-VIDEO output(Resolution:480*240) or simulation RGB output
15) Audio output:Stereo output of CD tone.
16) Support:SD card
17) Resolution:416*234 for 7inch
suerte un abrazo
Muchas grascias por la data !!!! Ahora le hecho un vistazo !!!
Gabriel
  • 1 mes después...
que bueno que está!!!!, quiero 1 para mi megane!!!!, cuanto cuesta?, se puede saber?.
Saludos!!
Yo lo busque en ebay y sale 530 verdes, con free shipping...
Que onda la durabilidad? Encastres? Va asi nomas sin marco ni nada? Esta confirmado que el comando satelital funciona?
Les dejo un link del de ebay: Stereo doble din para Megane 2
Hola, miren lo que encontré acá en Argentina, no se si crear un nuevo tema o si sería un aporte, bueno vean: CASKA Buenos Aires / [email protected] / Centrales multimedias / Stereos
Lo que me gustó a diferencia del que estábamos viendo, que este va en el lugar del display original, osea arriba del tablero, mucho mejor a mi gusto porque queda bien ubicado para todos los pasajeros y el otro me parece que solo lo ven el conductor, acompañante y el que se siente en el medio atrás. Y también tiene una función para el sensor de estacionamiento, en mi megane tengo los sensores!.
hola a todos si saven de alguno que quiera el doble dim original del megane 2 que me avise lo tengo en venta lo saque por que mi mujer me regalo otro estereo y vieron como son las mujeres cuando se les pone algo en la cabeza jajajaaj en este block estan las fotos saludos a todos
Ponelo en la seccion de ventas, igual como consejo, ponele el doble din que compro tu mujer, pero guarda el original, el dia de mañana a muchos les gusta mas el auto con las cosas de fabrica, si no necesitas la plata guardalo bien y listo!!
Saludos. Matias.-
  • 2 meses después...
